Mpg only drops in cold due to warm up.
It's ok just skip over the other comments that don't fit your agenda.
Firstly I don’t have an agenda.It's ok just skip over the other comments that don't fit your agenda.
No point commenting on the rest. Heating a ICE car is using waste heat rather than an electric heater.
‘Climate control’ is about 500-700W if you are referring to aircon which isn’t needed to heat a car. Obviously using aircon in summer to keep car cool os going to use power but this is similar for both
Again we were talking about cold weather where driving along in a motorway in a ICE the car is warm for free and the petrol fuel works the same and doesn’t need heating. An EV you have chemistry challenges and you are using the battery to warm itself and keep the occupants warm.
So no. ICE do not get impacted by a noticeable amount in the cold. Except they take a bit longer to warm up….
How’s that ?
To be fair even at 65p per kwh EVs generally are on an even keel with a petrol car. And also sorry to burst your bubble 2nd hand EVs are now in parity with petrol models
Not sure that's true at all - colder/denser air increases drag. Lubricants less effective so more friction of moving parts. Increased rolling resistance.Mpg only drops in cold due to warm up.
I actually replied to guy the saying he doesn’t understand why people don’t have an EV now they can do 300miles. I simply said without home charging there is no benefit.Well you was on about how expensive EVs are along with charging costs.
We get it you don't like EVs nor will you buy one. Not sure why you persist in this thread
new id7 with 88Kwh might do 300miles - if you sign up for likes of ovo smart charging (compared to octopus say) don't you get an unlimited number of home hours charging,
so could make a good dent in that 88kw, if you sleep in.
seems like id7 isn't doing well in pre-sales in china even at $35K it costs there
Don’t mention rain then. Or air density. You are talking about tiny numbers. But ok. Again ignore the point and make a strawmanNot sure that's true at all - colder/denser air increases drag. Lubricants less effective so more friction of moving parts. Increased rolling resistance.
Fuel Economy in Cold Weather
Cold weather and winter driving conditions can significantly reduce fuel economy.www.energy.gov
EVs are more affected by cold weather but ICE isn't immune.
Well you don’t need a degree to do 88 x 3.5 for typical motorway use.new id7 with 88Kwh might do 300miles - if you sign up for likes of ovo smart charging (compared to octopus say) don't you get an unlimited number of home hours charging,
I've no idea why you'd consider it a strawman, I've not been involved previously. You said:Don’t mention rain then. Or air density. You are talking about tiny numbers. But ok. Again ignore the point and make a strawman
Are you sure?Firstly I don’t have an agenda.
How’s that ?
motorandwheels.com
cleantechnica.com
15-20% is noticeable.The term noticeable is key. Tell me about how an engine runs cooler when it has a thermostat ?
Do you also know that cars’ fuel consumption increases by approximately 1.3% in winter? These stats already answer the question.
An engine isn't a homogenous block all at the same temp and the stat only reads one place. You also have other lubricated surfaces (gearbox/drive shafts/CV joints etc.) - all will be affected by temp.
Winter driving conditions and cold temperatures can have a significant effect on a vehicle’s fuel economy. For a conventional gasoline-powered vehicle, fuel economy at 20°F in city driving is about 15% lower than at 77°F.
The effect of temperature on electrified vehicles is even more pronounced. Hybrid vehicles, which rely on a larger battery, can experience a decrease in fuel economy of around 30%, while all-electric vehicles can experience a decrease in fuel economy of nearly 40% in cold temperatures. Tests were conducted in a controlled laboratory setting. For more information on the effects of winter conditions on fuel economy, visit Fuel
Which providers offer less than 65p? Your grammar suggests 65p trends high! Sorry to burst your bubble.
Hence my point about no benefit cost wise as public chargers are 20-25p a mile, Petrol 35mpg is 18p a mile. So you are paying more/similar for a massively inconvenient experience if you can’t destination charge (home/work)See you edited you post before before had chance to respond but did mention EV prices on last page.
Haven't used public chargers for quite some time so hadn't realised that pricing but even at 75p (would be cheaper if subribed to certain providers plans) the cost difference isn't all that big based on current fuel prices
And tbh he says he owns an EV but would like to see proof![]()
