Hi there
On the 911:-
- Interior rattle on certain road surfaces, never being able to locate it, almost sounds like a loose wire in the door panel, but it is minor and not annoying.
- Bigger rattle over bumps, this was annoying and fixed it, turned out it was under-tray hitting against a bolt which could be heard inside car, a bit of foam fixed it.
- Front brake disc, slight cracks around drilled holes, fine for road use only 1-2 track days left in them, shall replace soon or upgrade to girodisc all round.
On the Jaaag:-
- Odd rattles, but nothing major, it has done 150k miles and is nearly 15 years old, still mega comfy though.
- Fixed my miss-fire, turned out one of the new coil packs had failed under manifold, but the Jaguar specialist XJK replaced the coil under warranty free of charge.
- Diff, jerks at low rpms, known issue.
- Ashtray won't close, bit of blu-tac fixed that.
- Aircon don't work, pipes corroded
- Door locks have a mind of their own.
- Drinks oil.
So hey the 911 nothing really, the Jaaag many little niggles but I love it as it was an absolute bargain and has never let me down, apart from its radiator exploding one day, but that was fixed in a day for £240.
