I think this issue is just going to run and run.
Unlike the cards themselves, unfortunately
If I flash the new BIOS and find it too loud is it possible to go back to the old one?
I've gone ahead and ordered the thermal pads anyway.
Not decided if i will fit them or not yet though. I'll watch a few videos to judge how tricky it is first.
I applied the updated bios this morning. Ran witcher 3 for a bit, i still couldn't really hear the cards fans.
Not much difference in noise to be fair.
Looks dead easy.
Uh oh. Just had my first black screen on my FTW, lasted a good 5 seconds before it came back with a "driver has recovered from an error" etc.
Wonder if the card is about to detonate any time soon.
edit: ok so decide to update the BIOS to the latest. Went to the EVGA site, found the bios revision... check. Check against the s/n on the side of the box (which I still have thank goodness)... check.
Flash the Bios as the instructions say... no errors. Reboot. Oh joy. No fans. Yep they're not spinning at all.
Was the card set to master bios... yes. Did I download update for master bios.. yes, its the only one available for that revision. Its aint working. Check the BIOS revision number in Nvidia CP and GPU Z... yep identifying itself fine. Still not working. Had to switch to slave bios to get the fans spinning again as Afterburner was the only thing stopping my card from frying.
You couldn't make it up.![]()
The way they are claiming there is no issue and that this is just an option for people who want improved cooling is just offensive.
+1
If EVGA admitted there was a issue early on and did a recall then sent everyone a new GPU. I would have been like WOW! EVGA get my money forever, but they didn't so now they last me as a customer. Not happy tbh and wished I went with MSI.
"optional" fixes (sorry... Updates / improvements).Losing customers will cost them even more money in the long run....
I think most folks (me included) ,will agree with you, to one degree of another.
I suppose you could consider it a "virtual" recall anyway. As they have said that they will replace anyone's card with an updated one, at no cost to the customer. Though obviously (like any manufacturer) it would be most likely with a refurbished card. EVGA are not alone in doing this. And "yes" I can appreciate people not wanting their new card replaced with what in effect is a second hand part. Hence why I shall be keeping mine and just doing the numerous"optional" fixes (sorry... Updates / improvements).
But I don't think a recall and everyone getting a brand new replacement card was ever going to happen. If only because this would have cost EVGA millions of dollars.
TBC
