Permabanned
- 28 Nov 2003
- Shropshire
What a deviant.
Given your forum name I must bow to your expertise on milk
What a deviant.
no, you also said about water from the air magically getting through a container intot he milk this does not happen in the slightest.Er I thought that what I said.
Apparently the fat content, highest in full fat milk, predictably, separates out and is changed by freezing and it does not reconstitute back to the unfrozen milk's state, so can taste watery and somewhat grainy. This is much less noticeable in skimmed or semi skimmed milk. A lot of people round these rural parts still drink unpasteurised milk straight from the cow, and shun warnings of bacteria and live to a ripe old age. I must say it does taste a hell of a lot better in my opinion. Still not as good as a decent pint of beer though....![]()
yes online orders.What is that in reference to - online orders? Do they regularly deliver stuff close to the useably date when you order online and you then get a refund?
Dear lord no. Water can't just penetrate a container.
If you just pour milk into your freezer then you would be right. Most people do not. Most people have it I. Sealed container. It does not gain or lose everything at all.
As you now correctly point out it may split the rlmusion offat and water.
Milk will have no issue freezing regardless of fat content. How do you think ice cream freezes. -18c is cold. Although your principle of higher fat content lowers freezing point.
I think it's the other way round, they put shorter dates on so you chuck it away and buy more. Hence why most stuff is still perfectly fine a day or 2 past the use by date. Note that bread is usually best before which means it is perfectly safe to eat if it is still in good visible condition.
Also I often shop at Aldi on a Saturday evening and most times nearly everything only has maximum 2 days use by left which is no good if I'm shopping for the week.
Hi, are there any food items which can be used even after their expiry date has elapsed? For example a loaf of bread or a point of milk, can they be used a day or two after the expiry date? Also if bread is frozen and then defrosted, how long will it last and does it have to be kept in the fridge after defrosting. Can milk be frozen? thanks
Generally speaking when food go bad, it takes a while, it doesn't go from perfect to rot just because the clock struck midnight. Trust your nose, if it smells bad, then it probably is bad.
I keep bread in the freezer for AGES, take 2 slices out straight into the toaster to make toasts.
Milk I tend to just smell it, when milk goes bad, it's very easy to tell.
It's not bad until the rim is crusty!
Had some anchovies in the bottom of the fridge since Nov last year that say consume within 3 weeks. They smelt slightly off but chopped and chucked into a sauce you wouldn't know it.
Also recently used some mozzarella (the stuff in water) that was 2 months out and smelt fine.
yes online orders.
On their website they have guaranteed use by dates. They are very conservatively set tho, but they still manage to breach them.
e.g. on sandwich spread it usually comes with a week or so on it, but they are really passive and only set it at 2+ days on the website, but once every 3 or 4 deliveries it will arrive with less than 2 days on it, so in that instance they supposed to let you refuse the delivery.
Milk is not packed in a vacuum, so the is air in the container and the milk.
So it freezes and makes the milk taste like ****.
Don't freeze milk.![]()
You check each individual item before the delivery person leaves? Surely the guy delivering it just leaves the bags with you and wants to be gone?
Good to know though.
or dont say stupid stuff, rather than trying get out of it. a container has a very small air gap at he top and tha air gap wil contain 99% of water from the milk, and our talking about an absolutely tiny amount which makes zero diference.Milk is not packed in a vacuum, so the is air in the container and the milk.
