How much power do they put out after supercharging? Also, how common a job is it?
I had a play with one the other day I can only imagine had had something done as it wasn't easy to shake even as the numbers got higher, where as the stock fiesta sts ive played with in the past have been fairly poor
Power varies as there are a few stages, Stage 1, 2 and 2.5 but they also have different charger sizes as well as the new kit comes with a larger charger than the earlier kits for example.
With this the power ranges from car to car, I'm running 267bhp without cams yet someone with near enough the same setup is running 300bhp so it can vary.
There are quite a few running the chargers now so watch out
Will, I'm Jam0r on STOC
I've had no issues with mine apart from an injector wire coming loose which my local Ford garage sorted for me as I live in Birmingham and couldn't drive to JamSport with the car miss firing (I will point out JamSport we're very helpful on the phone at the time)
Mountune is the sensible route, I wouldn't go with the throttle bodies personally. The reason I say that is because the charger drives like throttle bodies anyway, you still need to rev the engine to get the power from it although not as much obviously. The extra torque is nice which you wouldn't get with the throttle bodies either.
I don't think there has been any major problems with charged cars, i've personally not heard any but I presume if you let it warm up as usual and don't constantly hit the limiter you'll be fine. I don't drive mine that hard and it still surprises me when I put my foot down when I join a motorway.
Have you ever been in one? Your fairly local to me, i've added you to MSN
The sound is enough of a reason to get the charger
