FAO rabc1690
just restarted with the multi at x44 but pc keeps restarting and wont boot into windows at back to x38
Ok, probably not enough vCore, i'm currently downloading what i think is the instructions PDF to your Motherboard...
it doesnt let you change to manual u have to set it by tying in numbers manually
I just looked in the Intructions manual, there really is no information at all about setting volts, nothing, it just say's "Advanced Voltage Settings" with a picture, and thats it!
Good Grief Gigabyte, People overclock, get over it! lol...
Try this, Highlight CPU vcore and use +/- on the Num Pad to change values, try 1.4v. see if that sticks :)
right the +/- keys work. it goes from auto - normal then starts at 0.000v and finishes at 0.300v is it 0.140 or there abouts im looking for??
Looks like its using an off-set system, i hate those :p
Try 0.150v, see if that will boot @ 44x, if not try 0.200.
