Diesel said:Its cack, period. I should know I've been driving one around for 3 years (thats what happens when you let old people buy you a car!).
Hopefully it'll be replaced in the not too distant future.
GT3 said:Noisy, old, unrefined, underpowered pushrod crap.
Assuming you are on foot. If you're driving they are unlikely to be able to pass you!Acolyte said:You can always tell which Fiesta and Ka's have the 1.3 engine when the go past you down the road.
emailiscrap said:Assuming you are on foot. If you're driving they are unlikely to be able to pass you!
Acolyte said:You can always tell which Ka's have the 1.3 engine when the go past you down the road.
GT3 said:Yeah, all of them![]()
I've had no problems with mine, its only 6 years old though and sub 50k on the clock.mrk1@1 said:Fairly robust though?
Mine doesn't actually have the usual ticking that a lot of them seem to.Acolyte said:You can always tell which Ka's have the 1.3 engine when the go past you down the road.
Both my Dads (2000) and girlfriends (1997) 1.25 16v seem to be more economical than my 1.3i.Tom|Nbk said:so do they do a reasonable amount of mpg or absoloute crap for a 1.3?
