First Build! :D
Well you want to fit that at the front, so it should look cool through the black vented slots. Are we on about the opticle drives??
Take that tiny fan out, as I think it will be a screamer. ok it is a 80mm
Fit a 120mm exhaust and maybe one on the side. what side:confused:
I doubt that small fan will do anything ;)
okey dokey:D:D
You wont need that many fans ;)
I run
2500k clocked to 4.2 (sounds good does that :p)
4GB RAM
6950 Dual fan edition.
I have 5 1900rpm 110cfm scythes and 1 140mm fan 60 cfm
I turn off three all the time, and the other three just spin at around 800rpm :)
Yes that 2500k is very nice:D want to sell it me:p
Ah ok, but what about if i get some high 120mm cfm fans for dirt cheap??
Sorry I was on the phone lol.
I meant fit the 120mm fan at the front (blue led)
80MM Meh! Take it out, it wont do anything.
One on the side? yeah them two grills on you're side case should allow two 120mm fans to be fitted to it
You're case specs for cooling
1 x Front 12cm Fan
1 x Rear 12cm Fan
2 x Side 12cm Fans
You wont need high CFM :)
Just make sure cable management is good
And yeah why not 2500k £12.54 plus £1.50 postage lol JOKE!
1 x Front 12cm Fan
1 x Rear 12cm Fan
2 x Side 12cm Fans
the fan at the front is a 190mm, it going down in size :o
2500k realy, what is your paypal:p
it measures 7.5 inches across diagonally
Lol :D
LOL
You don't measure fans diagonally ;) You measure going from east to west 7.5inches mean to me you have a 140mm fan ;)
Measure the fan from side to side or top to bottom.
I have just measured my 120mm fan and its 120mm across ;) And 6.5inches diagonal :p
LOL
5.5 inches 140mm fan on the front
Also what does CL5 mean as i lost out on the ocz ram, i have found some corsair xms2 800mhz pc2-6400 4gb, it has CL5 on the listing so what does it mean???
I have just won a new coolermaster 3 pin fan 120mm (No led) for £1.95 including postage :D
On my memory list is says 667mhz ram cas latency 4, but on the corsair 800mhx pc2-6400 xms2 ram it says cas latency 5, so i am presuming my board will accept cas lantency 5 ram as mine says 1066mhz, 800mhz, 667mhz on the website, here is the actual wording on the website below:::
2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
* Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
So will cas 5 latency ram work with my board???
Some pics:
I got bored :D
yet to get rid of the psu
Sorry about the messy carpet, brother said he would hoover today but didnt:rolleyes::rolleyes:
without psu:D
don't worry i earthed my-self out so nothing would get damaged :D
