First build thread
im trying to find the right ports to plug my front panel headers into the mobo and am having some difficulty
power led
power led+
hdaudio which has an ac97 wire attached
power sw
hdd led
usb
reset sw
All the front wire connectors go to the bunch of pins at the bottom right of the board, right in the corner.
The USB and Hd audio(leave the AC97part dangling) goes along the bottom of the board.
This is in the manual
the psu only has a 2x 4pin connector where thegraphics card needs 2 x 6pin. Is there meant to be an adaptor with the psu or the gpu?
The 2X4pin join together to go next to the cpu socket.
in the box of the PSU will be the PCI-E cables you need.
pci-e cables go from 8 pin to 6 pin dangling off is another 6 pin and 2pin
edit: yes they have red ends
Thats right, some cards need all 8pin (6+2pin) as they are that powerful.
Just push two of the 6pins in and leave the two 2pins dangling.
USe two different cables to balance the load across the PSU.
So you have two red connectors on the PSU? each cable has two ends 2X (6+2pins)
Thats right, the PSU has both a 8pin and 2X4pin,, use either:)
Some motherboards use a 4pin connection only, some need two 8pin stuck in them.
there are 2 8pin red connectors free on the psu - i have 2 identical forementioned cables.
i was thiniking i might have to use the second slot to power the front case fan
Not sure i follow,
The front case fan will use a flat four pin connector with slightly angled edges?
front case fan is 3 pin but there is no free 3 pin in reach of the wire.
is it possible to plug it into a 4 pin using a 3pin?
does it look like this? on the left?
yes but there is no spare molex on the mobo as the only availabe one is taken by the back case fan
You need to remove the rear case fan from that molex on the motherboard.
That is for when you have three graphic cards and the motherboard needs more power to run them.
All fans plug directly into the PSU cables!!!!
Except the Gelid cooler which does go directly into the board.
