First build thread
so that molex should have nothing in it ?
ill use molex adaptors on the dangling pci-e from the gpu and then plug the fans in that way?
The molex on the board should be empty.
Are you sure you have molex on the same cables as what is plugged into the graphic card?
The cables from the PSu to the graphics card should look like this
One end goes into the PSU the other into the card, there should be no other connections along its length.
Do you have the ability to post decent pictures up of any bits that trouble you?
And I mean decent, infocus, clear pictures and not like its looking through a milk bottle.
ye that is all sorted
all that is left is power connection for the hard drive and i want to double check frontal connections for power cause im sure something is wrong
im about to try powering it on, i can supply hq pictures yes if i have any trouble. i have no idea about BIOS and installing an OS ...
hopefully everything is going to work - stay tuned
ye display is up now - brings a menu wuth a few options then it jumps to a screen saying
"reboot and select proper boot device or insert boot media in slected boot device and press any key"
Good,
Set the boot order to DVD rom first and the Samsung F3 second, you can disable the other options.
Is the time and date correct?
save and exit, put the windows disk in the drive and let the PC boot from it.
