- 12 May 2014
Truly stunning build there!
Amazing build and a beautiful setup as a whole, love the all black with just a touch of lighting!
@LiE with regards to the top mounted radiator and RAM clearance, would you have been able to use taller RAM if you had gone for a 30mm thick radiator instead of a 36mm? I'm planning a Define 7 build and trying to work out if I can fit a 30mm thick 420mm radiator in the top and not have to use low-profile RAM. My only other concern is the I/O shield. Your pictures and details give me the most hope yet that it might be possible!
Yeah it's definitely gonna be a close call, just trying to gather as much info as possible from people with similar builds. Appreciate the quick response!Im not sure, it’s pretty tight there.
