- 7 Mar 2013
- Caistor
Thanks for the reply!
Rads:- The rads are important for an aesthetic point of view as I'm going for a black and white theme
Pump: - OCuk don't seem to sell a controllable pump?
EVGA bridge will delete
The crystal link set I didn't know which one to use so I put both and would return the other...
Thermal compound: - what would you recommend?
Q: - good point! Will do
Compression fittings: - really? Damn like the look of those more than the Primochill onesDo bitspower not do acrylic fittings??
Rads:
Well, seeing you're buying two of them, that'll cost you an extra £60...
Pump:
D5 Vario have 5 speed settings, also known as MCP655
Crystal link set:
If you are using this set, you will also need to buy the Bitspower Multi-link fitting, also known as the C47 push fitting
For the tubing that you've bought, Bitspower's rigid tube fittings are incompatible, you will need the Primochill Revolvers or Monsoon.
If you want to stick to Bitspower, the enhanced multi-link fittings are their rigid tube compression fittings.
HOWEVER the only rigid tube compatible with Bitspower compression fittings are the 10/12 E22 tubes or their own branded tubes.
Hope this helps.
Edit:
Thermal compound:
I have always used Gelid GC Extreme, but the recent release of thermal grizzly seems to take the throne of the king of non-conductive thermal paste, at the cost of a bigger price tag.
The performance difference seems to be 1 to 3C, idle or under load, but either way you cant go wrong with either of them.
(P.S. EK official choice is the Gelid GC Extreme)
