- 24 May 2011
I think you should start with a non rigid tubing and then move on to acrylic tubing as its very hard to align and difficult to reposition components once its done.
I did a normal tubing build in the past. This is for something to do, so I don't mind taking my time with it. I've also go rotary connections just in case things get too tight or complicated in the build. Although I'm still trying to figure out the best tubing for SLI 980 Ti's.
