@MikeB888 top is your parts, and they building it for you at that price?
so
prices on prebuild £2200
NV5 case £105
d30 reverse fan tripple pack £78
aio glacier one d30 fan £155
7800x3d £430 overpriced at mo as 9800x3d out of stock
32 gb ram £100 overpriced for old speed ram
saphire pure 7800xt gpu 450
B650-a strix mobo £190
1tb sn770 £63
psu unknown
price without psu 1570
so prebuilt is £660 more than parts less windows and psu...they've prob put the phanteks 1200 revolt in there at as way overpowered for a 7800xt, but it's expensive and they trying to get rid of stock..psu by itself is £195, then you have to get the cables as not included which are £70 for white, so paying £265 for psu and cables......hmm (there's a reason no one's buying them)..or just get the phanteks amp gh 750w for £95, 850w for £115 or 1000W for £139...cables included
don't bother with windows, they'll charge you £100 for the copy...even prebuilt you can ask for it without, and then buy a copy for fraction of price(google it)
either way you're paying way over the odds for it as the psu is overkill by far
your build
vision case white £140
9800x3d £450
asrock rs wifi £220
64gb 6400c32 £255
4070super duo £570
sp750w £125...sfx psu??why
pA 120se £40
t500 2tb £134
total £1934 without windows..prob with your build is you have no fans in the vision case and being glass at top I'd prob want ai aio on side and 3 intake at bottom sl120 £90(you'll want reverse on bottom so nice side facing in) and galahadII trinity slinf 360mm for exhaust £170...so add £260 to your build less perrless assassin...so £220...again, a lot of money for a 4070super build...at this price really s/b a 4080super in there
even with zero knowledhge, building a pc isn't hard..if you can follow lego instruction, you can build a pc. the £300 saving on having it prebuilt will bump your pc to a 4080
but if you adamant getting it built for you....
out of the 2 I'd choose the 9800x3d build, as they charging £300 to build it, just swap out you sfx psu for an atx...but you'll need to add fans etc case will look empty without them and also an oven as front side top is glass..OCuk will charge a bit more to install them...used to be £10 a fan but s/b less as they all linked together
before i say more, I have an 011d evo with 9 infinity sl fans and an air cooler...I get away with the air cooler as i have 9 fans andwith 6 pulling in air, and 3 exhaust out the top and plenty of space at back, i have plenty of airflow. It cost me a small fortune...yeah, it's ok..would i do it now...no. I've got an nv5 case also with 8 d30 fans also, but got those 2nd hand...
plenty of nice cases now that wont break the banks that come with fans
you have the C5 above..i wouldn;t go fat again so antec C3 more my style now...also look at mag pano m100r pz...matx case but can get the white msi b650M project zero mobo...gives you a clean look...don't need anything else if a 4070s...case comes with 3 reverse blaade fans intaking on side..so decent airflow coming in, so air cooler option again, and one at back pushing out, helping the cooler
