What are the fans like on the PC7? Does it now come with 2*120 as standard now (i.e the +II)? Are they quiet? Are they lit?
The PC-7 does come with 2 120 mm fans. One is low on the front panel in front of the drive cage. The other is above the IO shield right behind where the CPU cooler will be. They do not light up and in my experience they are very quiet, near silent even at 12V.MrJubbly said:What are the fans like on the PC7? Does it now come with 2*120 as standard now (i.e the +II)? Are they quiet? Are they lit?
The ones i got with mine were pretty loud at 12v, but seemed to push a decent amount of air. They can be easilly changed to 7v or even 5v depending on how cool you need your case. In mine i have 2 ambers at 5v and its very quiet, still not silent though.BillytheImpaler said:The PC-7 does come with 2 120 mm fans. One is low on the front panel in front of the drive cage. The other is above the IO shield right behind where the CPU cooler will be. They do not light up and in my experience they are very quiet, near silent even at 12V.
Deks said:Have whittled my choices down now to either the TJ-09 or Akasa Eclipse 62 having nw discounted the Antec 900 due to being too cramped.
I like the look of the cooling on the TJ-9 I still have reservations on the eclipse due to only 2 120mm fans. I have an Antec P160 which only has 2 120mm fans and I dont think its enough. If I got the eclipse ide have to think about adding a 120 on the top altho the PSU would have been better on the bottom of the case for this
Decisions decisions
Deks
techmob said:i am debating the eclipse and the reason i havn't so far, is it only has 2 fan slots, if it had a blow hole at the top then i would deffo get it
although its a wide case, is 2 fans going to keep it cool enough
geff_r said:I don't really like this new trend of putting psu at the bottom
all it does is make for cable management issues and the cooling
positives cannot be that big a difference however i too like the tj09
and would have got one if i were rich.
as I too, was confused on which to get.
