First post - And its a another 'Which Case?' dilema
Received my Akasa Eclipse yesterday and open getting home and taking out of the box I am extremely dissapointed in the quality control. The side panel does not fit very well and at the bottom right corner the panel can actually be pushed and moved 2mm which causes a terrible rattle!!
I think the panel is to blame and not the case as I purchsed a see through window on a whim and this is fine altho I have now decided to keep the plain black side fitted. I will be phoning Overclockers later today to see if they can exchange the side panel (at their expense).
Just thought I'd share my views. I am taking pictures of the new build and will post these when / if it all goes together and works
Cheers
Deks
Pretty sure I'm going with the PC7 now.
BillytheImpaler said:
The PC-7 does come with 2 120 mm fans. One is low on the front panel in front of the drive cage. The other is above the IO shield right behind where the CPU cooler will be. They do not light up and in my experience they are very quiet, near silent even at 12V.
Is the fan on the front panel visible? i.e. if I replaced it with an LED fan would it be seen. Just thought I'd introduce some subtle 'bling', if there is such a thing :D
Cheers
Jubbly
