Hello folks!
I have been a long timer user of air cooled PCs and have built my computers for many years however have always shied away from water cooling. I have however put custom coolers on graphics cards and a variety of other component modifications so I have no issues with getting my hands a little dirty.
I have recently purchased a 3090FE to replace my custom cooled 2080Ti which had a Raijintek cooler on, and it is sadly quite noisy when I fire up a game and is something I want to fix.
I would like some general guidance on where to start and what bits to look at:
I believe my case will fit a 240 or 280mm radiator and I am a massive fan of Noctua fans, the most important thing to me in this is noise levels over all else.
Here is what my system looks like right now:
Intel 9900k
Z390 MATX Motherboard
Fractal Design Meshify Mini-C Case ( https://www.fractal-design.com/products/cases/meshify/meshify-c-mini-dark-tempered-glass/black/ )
Noctua NH-D15 ( https://noctua.at/en/nh-d15 )
A variety of Noctua Fans
So my questions:
What radiator should I go for?
What pump and reservoir should I go for?
What tubes and fittings should I use?
What waterblock should I use for my 3090FE?
Any other tips or things to consider?
Intel 9900k
So my questions:
