Thanks for the feedback, I think its most sensible to go with a full loop as mentioned.
The 3090 is *really* long, but the PCB is considerably smaller.
I wonder if its worth going with one of the radiators with low profile radiator and fans?
low profile radiators give low profile cooling. you want as good as you have but with less noise and low profile rads won't give you that.
I also wonder if something like the 'SWIFTECH APOGEE DRIVE II' which is a CPU block and pump integrated can save some space?
There is a really nice block/pump here with something like this you could then realistically go top rad and front rad. A 240+280 would be enough to cool but whether it could get both good temps and be quiet is another matter.
Perfect for small form factor builds although filling might be a bore. Somehow if silence is the driving factor you need to overwhelm the heat generators with radiators because powerful fans=loud fans.
