Flash Memory Stick - HELP
25 Nov 2011
My Patriot Supersonic Pulse, was formatted by Memtest86+ and seems to be completely destroyed. MT formatted it for a boot run. Since then it has no volume, no files system and Windows7 64bit cannot format it.
What next?
Use Disk Management to create a new volume.
So go to disk management, find the USB drive, right click on Unpartitioned space > New Simple Volume...
and the rest is pretty self explanitory :)
Edit: also your sig is too big
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
I had this problem the other day after I formatted a USB stick to install chrome on a (very old) laptop.
Ended up having to use "Gparted"
google it
download the iso
burn it to a CD
boot with the CD
plug your drive in and use the partition tool to delete/format/whatever to get it back to its original state.
My Stick was so buggered that windows disk management saw about 7 unknown partitions that it could not delete, and explorer would not even show it, so all the 3rd party windows format tools went out the window. Gparted did the trick in about 5 mins.
Good luck
-Edit - Gparted is free
