You get in your car, its quite warm inside, you open your windows straight away and you're telling me your climate control just sits there as normal? No, it doesn't - it blasts on full for ages whilst it struggles to bring the temperature down in the car, which it cannot to because it all escapes out of the window.
No, thats not really how it works. It'll blower stronger than usual for about 20-30 seconds, and then it settles down. Even with the window open. I often drive around with the windows open and the climate copes perfectly without throwing a fit, without going bonkers, infact.. just behaving totally normally.
It is so good you litertally set-and-forget. Set the temp and never touch it again in your life. If its sunny outside it adjusts, and you get colder air. If its cold outside it adjusts, you get warmer air, if you want your window open, open it - the system wont go mad, it wont stop functioning, it'll just.. continue as normal. You wont even notice.
Once you understand climate control, its a set-and-forget system. It is brilliant.
Wow, I think it is in fact climate control users who are kidding themselves. Just to reiterate - I don't like climate control in manual. I also don't like driving around with my windows up.
FFS, why is it so hard to understand - climate control doesn't suit my usage, nor do I like climate control.
I'm intelligent enough to work out what my own preferences are and what suits me and what doesn't.
I don't think you understand what its for, how it works, how it does it, etc. You don't have it, you've convinced yourself dont want it anyway based on a misguided assumption on how it works. Your Mondeo doesnt have full climate anyway does it? It's SATC, this is not the same thing.
It suits everyones usage - because it just sits there in the background and never, ever bothers you.
