It's about time this was updated.
At this minute and time the best solution for folding I think is to download the latest folding client, it has quite a lot of options and caters for new and old gpus by allowing you to add the tags for the newer cards to fold the better units , and netting you much higer PPD.
folding program
http://folding.stanford.edu/
passkey
http://fah-web.stanford.edu/cgi-bin/getpasskey.py
the first thing to do when you've installed the program should be to click the folding icon in the corner and advanced control , the client will open and youll see a bar that says folding power , slide this across to full otherwise gpus wont work !
you will need your set your user name, team number and passkey which is done by clicking the folding icon > advanced control > configure. This takes you directly to the identity page
as you can see the team number is 10 , if you don't put 10 you wont be part of this team
now once you've done this you will need to set up the tags on your gpu client providing you have a 600 or 700 series gpu , the AMD range of cards im unsure as to what model you should add the tags to be anything like the 7850 / 7870 or 7950 / 7970 would be best.
ok onto setting up the tags.
if you click the folding client and then click advanced control it will bring up a nice looking client.
you need to click the CONFIGURE logo at the top , you will now be met with 7 pages as you will see , you need to click the slots, in thereyou will
see cpu and a gpu , double click the GPU , now another box will have opened, if you enlarge this box you will see at the bottom there is 2 buttons
add and remove, you need click the add button , yet again another box, dont worry this is the last box !!!. In this box you need to type 2 things as such
value: advanced
now these have been typed, click ok, now on all of the boxes click either save or ok will youve closed all the boxes down
couple of pics to show what I mean.
when you have clicked configure and selected the " slots " page it will look like this.
once you have double clicked the GPU icon and clicked the " add " button , you will see from the below picture exactly what I mean by typing in the values into the boxes.
