- 28 Sep 2017
Hey everyone,
Connor here - hope you're all having an easy end to the week, almost time to escape the office!
Figured I'd talk Glen into giving me some freebies for you all with another forum review opportunity for the new Phanteks P600S.
It's their latest Silent Chassis, complete with quick-release sound insulated front and top panels.
The case has two magnetic lock hinged side panels, with one being tempered glass and the rear side panel being closed with pre-fitted sound insulation.
On a closer look you'll see the internals are very similar to the Evolv X, with a few noticeable changes, for example if you take off the front and top panels you'll find Phanteks new dual layer mesh panels underneath.
They've got a honey-comb like appearance, allowing much better air-flow than traditional high density mesh, meaning users have the option to easily increase air-flow to core components when needed.
Like with all Phanteks cases there's an abundance of cable management, innovative features and 3 x 140mm fans pre-installed as standard. (There's also refreshingly, no built in RGB).
Anyway, should you like to be in the chance to receive one all you have to do is:
- Let me know you plan to build in it
- Tell me what colour you'd like
- Agree that you're okay to post a small review on both the forum and the product listing in exchange for the sample.
- Bonus points if you're happy to post a couple of photos for your finished build for Danny over on social.
Easy. Good luck and hope you all have a fantastic weekend!
Phanteks Evolv X at a glance:
- Silent mode with effective sound-proofing thanks to triple layer of insulation built into the front, side and top panels.
- High Airflow mode by removing top and front panels to reveal Phanteks new high-airflow, dual layer mesh.
- Hinged side panels with front tempered glass panel and rear sound insulated panel for easy access to components.
- Built in PWM fan hub that allows low RPM or silent running with 3 x 140mm fans pre-installed.
- Supports GPUs up to 435 mm long, vertical installation optional, CPU coolers up to 190 mm
- Dual system configuration with support for up to 1 x E-ATX motherboard and 1 x ITX top mounted motherboard (with ITX upgrade kit accessory)
- Air cooling support for up to 3 x 140mm front mounted fans, 2 x 140mm/3 x 120mm top mounted fans and 1 x 120/140mm rear mounted fan.
- Water-cooling support with support for up to 1 x 420mm/360mm front mounted radiator, 1 x 280mm/360mm top mounted radiator and 1 x 140mm/120mm rear mounted radiator.
- Storage capacity for up to 10 x HDD and 3 X SSD with multiple mount positions. (3 x SSD brackets and 4 x HDD caddies inc.)
- Dual-lane cable management with built in velco straps. Sliding panel and GPU cable covers to adjust depending on motherboard/ GPU size.
-Front I/O with hinged cover includes 1 x USB 3.1 GEN2 Type-C, 2 x USB 3.0.
- Available in Anthracite Grey, Glacier White and Satin Black.
Phanteks Eclipse P600S Glass Silent Midi Tower Case - White @ £134.99 inc VAT
Premium Midi-Tower P600S Silent in White, tempered glass side panel, optimised for air cooling, space for max. 420 mm radiator, supports 435 mm graphics cards, three preinstalled fans
Only £134.99 inc VAT.
ORDER NOW
Phanteks Eclipse P600S Glass Silent Midi Tower Case - Black @ £134.99 inc VAT
Premium Midi-Tower P600S Silent in Black, tempered glass side panel, optimised for air cooling, space for max. 420 mm radiator, supports 435 mm graphics cards, three preinstalled fans
ORDER NOW
Phanteks Eclipse P600S Glass Silent Midi Tower Case - Gunmetal Grey @ £134.99 inc VAT
Premium Midi-Tower P600S Silent in Gunmetal Grey, tempered glass side panel, optimised for air cooling, space for max. 420 mm radiator, supports 435 mm graphics cards, three preinstalled fans
ORDER NOW
Phanteks Eclipse P600S Silent Midi Tower Case - Black @ £127.99 inc VAT
Premium Midi-Tower P600S Silent in Black, sound insulated side panels, optimised for air cooling, space for max. 420 mm radiator, supports 435 mm graphics cards, three preinstalled fans
Only £127.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
