Anyone know if you can put drive cages from the R4 into the bottom of this? I like the reduced size of the S but i need a couple of HDDS as well as the 2 SSDs.
I have just bought this case with normal side panel, no window to keep as quiet as possible. Is the windowed one much noisier? Can you get just the windowed side panel? I see you can for the R4/5 etc but supposedly these wont fit?
Been looking at this case as part of an upgrade for my 2500K (new case, graphics card, SSDs etc) but I read someone saying that they were not able to fit three 140mm Noctua fans on the mounts at the front of the case, even Fractal Design's own 140mm apparently won't work. Something about the mounting holes not going high enough for all three fans to be properly mounted. Anyone have experience of using three 140mm on the case? No point me buying a full set of fans only to then find out I can't fit them.
I've got three Fractal 140's at the front. It was a little tight but only by about 1mm from perfect but was easy enough to squeeze them in.
