idk,it should work fine with a single 8pin from either or both psu's,its hard to say whether its the board or the cpu,
take out the cpu,usually when no cpu is installed the board just lights up and stays lit,if that happens then could be cpu,if it shows same symptoms as when the cpu is installed then lookslike the mb
im only guessing though,i think the easiest route to take is rma mb to gigabyte just to be sure,shouldnt take long as they are in milton keynes
