Shame they're so bloody heavy - makes even posting one an expensive experiment ha ha. .
Check out Parcel2Go rates. Much cheaper
I can only presume adding the pump was pure coincidence as its a solid 12v unit.
I think the motherboard uses 5v from the 24pin connector, the motherboard detecting a lack of 5v must be causing a shutdown. It also explains why I can jump the PSU and all the fans, pump, drives spin up fine...as they are all 12v.
The guy nearly got a man-hug when he told me there was a fault!
If you look at THIS picture it shows the 24 pin connector has quite a few +5v pin outs.
RMA request with corsair has been sent.
PSU IS FAULTY!!!!
The +5v line isn't doing much of anything
Time to start the RMA proceedings!!!
Very very happy chappy right now.
Excellent news. Pat on the back for yourself for such thorough testing and checking![]()
you need to use parcelmonkey,should cost you around £8 with vat to send nextday and they come and collect,just print off the label ect,
Corsair are good.
I don't see coming from same factory as meaning all are same quality. Manufacturer mankets what customer specs,.. which may or may not be good or great quality components.
