Being able to smile after what the gremlins have put you through is a good sign indeed.
This does not help you at all but I rebuilt my PC at the weekend - I turn on the PSU and the board lights up fine, then I press the power button on the front of the case and absolutely nothing happens .. panic time! It turned out I had managed to plug the CPU power cable in upside down on the motherboard end .. I thought it was a bit difficult to plug in![]()
I swear the PC gremlins are in league with the sock monsters! True story
Glad it's coming alone PGI![]()
The guy at the local store says he will test the unit and should only take a few mins, any ideas as to what exactly he will do? i.e. just plug it into another machine or use some sort of load bank?
Most places will just short it out and see if it works.
They don't have the money of use to buy a PSU load tester.
No, they are sitting in amongst the dust pointing and laughing at me![]()
