Yeh last one Matt. Also getting 900 quid tax back one of these days. Was looking for an upgrade but not 2 sure yet. that sapphire 290x looks good though
Matt I can limit fps just fine like that. But when i try to use the Program in the 1st post with it rivatuner doesnt work for some reason
Has anyone got this working? Could've sworn i saw PG Tips post some 4K fifa screenshots the other day.
Anybody got side by side screenshots of this in game?
change forceBorderlessFullscreen from true to false. crossfire only works on fullscreen.Trying to get this to work on Dark Souls 2 on 290s crossfire
Once activated it shuts down crossfire and my fps takes a hit? Looks so much cleaner downsampled from 4K too.
Crossfire works normally, but as soon as I activate crossfire stops working, any suggestions?
# Lines starting with "#" are ignored by GeDoSaTo and used to provide documentation
# read them before changing anything!
# Internal settings
# The amount of logging output for debugging purpose.
# Should be set to 0 if everything works fine for performance reasons.
logLevel 0
# Graphics settings
# The actual rendering resolution you want to use,
# and how many Hz you want the game to think it works at.
#renderWidth 5120
#renderHeight 2880
renderWidth 2560
renderHeight 1440
#renderWidth 3200
#renderHeight 1800
#renderWidth 2560
#renderHeight 1440
reportedHz 60
# The resolution you want to downsample *to*.
# Should generally always be your output device pixel size and frequency.
# Writing something not supported by the display here will probably cause a crash.
#presentWidth 2560
#presentHeight 1440
presentWidth 1920
presentHeight 1080
presentHz 60
# How many vertical traces to wait when presenting
# -1 = unchanged
# 0 = no vsync
# 1 = standard vsync
# 2 = half refresh rate (e.g. 30 on 60 Hz)
# 3 = 1/3rd refresh rate, etc.
presentInterval -1
# The type of scaling you want to use.
# bilinear: what GPUs generally do, cheap performance-wise
# bicubic: higher quality, more expensive performance-wise
scalingType bicubic
# Emulate exact flipping behaviour
# requires some extra performance/memory,
# but may be important for some games to work
emulateFlipBehaviour false
# For games which use strange methods to query resolutions,
# injecting a new one might not work. In such cases, you can try replacing an
# existing resolution. E.g. "overrideWidth 800", "overrideHeight 600" to replace 800x600
# 0 = override disabled
overrideWidth 0
overrideHeight 0
# Windowing settings
# Hides the mouse cursor, at all times
# options: "true" (= hidden) and "false" (= unchanged)
hideMouseCursor true
# Forces borderless windowed fullscreen mode instead of fullscreen mode
# options: "true" (= force borderless windowed FS) and "false" (= unchanged)
forceBorderlessFullscreen true
# Dark Souls 2 settings
## AA
# AA toggle and quality setting
# 0 = off (best performance, worst IQ)
# 1 = low
# 2 = medium
# 3 = high
# 4 = ultra (worst performance, best IQ)
aaQuality 4
# AA type
# either "smaa" or "fxaa", depending on your preferences
aaType smaa
## SSAO
# Enable and set the strength of the SSAO effect (all 3 settings have the same performance impact!)
# 0 = off
# 1 = low
# 2 = medium
# 3 = high
ssaoStrength 3
# Set SSAO scale
# 1 = high quality (default)
# 2 = lower quality, lower impact on performance
ssaoScale 1
## DOF
# Enable Depth of Field
# false = off
# true = on
enableDoF true
# Select the type of DOF effect
# basic = basic pseudo-Bokeh DoF
# bokeh = shaped circular Bokeh DoF - WARNING: high performance impact
dofType bokeh
# Bokeh Depth of Field radius
# default = 1.00
# higher = more blurry (e.g. 1.1)
# lower = less blurry (e.g. 0.9)
# note: small changes make a large difference
dofBaseRadius 1.05
## Post
# Enable Postprocessing
# false = off
# true = on
# For in-depth configuration, look in "assets/post.fx" or "assets/post_asmodean.fx"
enablePostprocessing true
# Postprocessing type
# durante = basic postprocessing adapted from SweetFX (dark, local contrast)
# asmodean = postprocessing by Asmodean (with tone mapping, softer)
postProcessingType durante
## Bloom
# Enable HDR Bloom
# false = off
# true = on
# For in-depth configuration, look in "assets/bloom.fx"
enableBloom true
# Texture settings
# Dump game textures loaded using d3dx to textures\[gamename]\dump\[hash].tga
# if you enable override at the same time, the overridden texture will be dumped
enableTextureDumping false
# Override game textures loaded using d3dx with those from
# textures\[gamename]\override\[hash].(dds|png), if available
enableTextureOverride false
# Mark textures with their hash (for texture modders)
# WARNING: extremely slow if a game loads many textures
# (if you think a game crashed, it's probably still just loading textures)
enableTextureMarking false
# Mouse settings
# you may have to play around with these a bit to get mouse input working correctly
# while downsampling in some games
# Modify the mouse position reported by "GetCursorPos" when downsampling
modifyGetCursorPos false
# Modify the mouse position set by "SetCursorPos" when downsampling
modifySetCursorPos false
# Intercept the WindowProc callback of the game and adjust mouse messages when downsampling
interceptWindowProc false
# Adjust the mouse position reported in peeked Windows messages when downsampling
adjustMessagePt false
