GeForce GTX 590 Key Features Revealed
IMO both the 6990 and the 590 are failed cards but I tolerate that some may disagree.
I wouldn't also go as far as slating Nvidia for the pricing as they generally put a significant mark-up on their products and yet their priced their lead card at the same level as the competitor. As for the UK pricing - no comment from me. False economy really.
I agree... that the 6990 can't top a "broken", "unworkable", "hot" and "loud" architecture with its supposedly superior design means its a failure I guess and the 590 its silly pricing when I've been using a similiar performance setup (GTX470 SLI) for months now and cost me half the price of a GTX590.
Would have to agree. Hopefully the next generation is better.
I don't understand this part, have some people said that to gain the upper hand or something? :confused:
But it did. :confused:
They are pretty much on par out the box give or take the odd benchmark/settings neither is significantly slower or faster than the other.
Theres been a lot of comments about Fermi being a bad design, yada yada and can't possible be "workable" as a multi GPU setup... yet its seems it can atleast match the competing design that some people have held up as being the superior one...
Smaller die, near equal performance=superior.
Oh, I see.
Well at 600MHz it's good and reviewers have been doing safe OCs but the cards have been dying due to the power management. Wouldn't say it's matching for reliability. :p
Don't forget Fermi also has superior tessellation and geometry shader performance in that bigger die.
If its a bigger size its performance should be but its performance is not much better in proportion to its size & in areas that are used in most games.
this is something i can never grasp, maybe because ive never had a noisy card/s
but surely if your playing games, the sound from the game drowns out the fan noise ?
Yea but what seems to be the issue is when the game you like to play is Furmark and for no reason you put powertune to +20%. Now if Furmark had a good soundtrack and effects the problem would be solved...?
