But if OCUK can get them in cheap enough....![]()
they arent cheap. dont expect one for less than the price of the MK-26
OcuK have no chance of getting any.
OcuK have no chance of getting any. All they will be able to do is get the 680 version and use a shim.
Arctic Accelero Hybrid VGA Cooler @ £74.99 inc VAT
AMD Radeon HD 7870, 7850, 6970, 6950, 6870, 6850, 6790 • nVIDIA GeForce GTX 680, 670, 580, 570, 560 Ti, 560SE
Was £102.98 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
Ile get your coat MattGood work OcUK and no hanging about.
the 7970 needs a shim but the 290 core is flush with the core surround so i dont think a shim will be required
i will test on monday when the acceleros arrive.
Fair do's. Arctic told me themselves the 7970 version is EOL though. That's all i ever said and that is still correct.
EOL does not mean not still available though. Just means end of line by the manufacturer, stock can still be sitting in warehouses, as RJK has proven by finding some.![]()
Buy an Nvidia version and use the shim.... That way you can use it on either AMD or Nvidia.
If you buy the AMD version you can't use it on Nvidia.
What sort of temps can you expect to see using one of these over a lets say an EK block or the stock cooler on an iceQ card?
Looking at you LtMatt as you have tried one on your 7970![]()
Custom loop with a good block like ek will wipe the floor with one of these, a good loop on a 7970 would give you high volt/clock temps in the low to mid 40's.
But cost considerably more.
