what about crossfire, would reference be the best choice due to dumping the heat outside the case
Zero space between cards - Forget it.
One space between cards - Reference is best or something like the Sapphire which has powerful fans.
Two space between cards - Pretty much all models are fine.
The good thing is they don't have a CF Bridge so you can put them as far apart as your MOBO allows.
That's a very good point.
Said the mullet from the red side
Oh the irony
One problem with using the last slot on the mobo with the stock cooler is it covers the connectors there with very little space under the cooler.
Same here, if i was using amd cards. The board is 3 way xfire compatible, (dual sli). But the 3rd slot is x4. I couldnt even run my pcie audio card in it when i had sli as it meant the cards wouldnt run sli. Had the opportunity to buy a Maximus VI extreme a few weeks ago but passed on it.Also a good point. I can't use the final slot on my mobo for several reasons. One my case is too small. Two the psu gives the third slot card no room to breathe. Three my third pci-e slot runs at x4.
Lightening vs Tri X bring that on!! I will report this back!!
I think mid-end next week, shall see if I can do a special on it on pre-order only on Monday.
HI there
1-2 days on the regular 290, X version still awaiting ETA.
Here is that special PRE-ORDER ONLY price you guys wanted:-
# Sapphire Radeon R9 290 Tri-X "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card (11227-00-50G) @ £359.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 1000MHz
- Memory Speed: 5200Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£389.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Each card should at least have a small space between them, about an inch, otherwise they could get too hot.Thanks Gibbo, am going to order a new rig with 3 of these for sat delivery
Will 3 of them in an open HAF XB case ok? 2 of them close together the other spaced..
Also, what PSU in stock would you reccomend to power 3 of these?
Many thanks
