Just as I began to get used to the noisy fans I now have continuous rattling from the thing. Anyone else have same problem?
I have just looked at fans and they are spin, stop, spin, stop - that can't be right can it?
I had to perform a BIOS update on my Gigabyte 2080 gaming overclock to stop that happening although I still use a custom fan curve. You'll probably find if you set a fan curve in Afterburner with minimum fan speed above about 33%, the fans will run continuous at idle with less noise. Anything less than 33% fan speed can result in that stop/start issue.
Update:
Received a lovely replacement 2080ti from Overclockers today. After 6 weeks without a gaming pc I now have one and it's not making a racket nor stopping etc. You don't realise what you have until it's gone.
Even worse during this Isolation period![]()
