Its great fun when i lived back in sunny Norfolk i used to go flying quite often at Swanton Morley AFB, it used to cost me about a £10 an hour, cheaper than my driving lessons.
Damn thats stupidly cheap. My local (Newtownards) costs £80 for 30mins!
He looks about 15 and he has a Plane?![]()
Are you both flying or something, or is it locked to one side? I'm confused![]()
There are two yokes. When one person moves one, the other one beside moves with it. Meaning, turn one yoke left, the other turns left also.
Ah cool. Any reason why there are two?
Well they are there for both pilots to be able to control the aircraft. Say for example if one of the pilots fainted or collapsed then the other pilot would quickly be able to take over.
Well generally in small aircraft there are dual controls to allow for training. However as has been said in commercial aircraft there are dual controls for a number of reasons. If one pilot becomes unable to fly then the other can take over, also If the other controls break then there is a redundancy.
Took me this long to notice, but don't you fly the A320/321? Only noticed when i installed FSX that the A320 has a joystick style yoke rather than the two handle bar type that is common in most aircraft. Do you find it easier or harder to control with it? Just looks more tricky since you only use one hand (well i guess you probably would have used one hand anyway since your other would be used for the throttle, flaps etc on landings).
Snip
