are you stiring it with a spoon? if so get a shaker and shake hell out of it, or blend it if you can.
SteveC said:Hi everyone,
Im looking at buying a weight gain formula which also contains protein. I was looking at Maximuscle Progain....it seems to have good reviews. Can anyone recommend any weight gain formulas? Can anyone recommend any sites to buy them?
Thanks
DuncanK said:Make your own weight gainer!!!
Buy some protein powder, and some finely ground oats/maltodextrin, pint of milk and a tablespoon of peanut butter! Blend it all together and down it.
Much better than one from a tub and you can control what goes in it!
Try checking out www.bulkpowders.co.uk & www.myprotein.co.uk for the items that you need!
SteveC said:lol cheers for the suggestion but sounds disgusting! plus im looking at a water based supplement, as it is easier to absorb and often milk based supplements cause wind and stomach problems
Balddog said:New routine...anyone got any input?
Flat bench 5x5
Incline bench 3x8
Flyes 3x8
Biceps#1 3x8
Biceps#2 3x8
Light Cardio
Deadlift 5x5
Barbell row 3x8
Good mornings 3x8
Pulldowns(too fat for pullups) 3x8
Light Cardio
Heavy Cardio
Various ab stuff
Forearms
Overhead press 5x5
Lateral raises 3x8
Frontal raises 3x8
Rear raises 3x8
Shrugs 3x8
Triceps #1 3x8
Triceps #2 3x8
Light Cardio
Heavy Cardio
Various ab stuff
Squats 5x5
Lunges 3x8
Leg press? 3x8
Stiff legged deads 3x8
Light Cardio
Heavy Cardio
Various ab stuff.
Fusion said:Did you check my link? That will mix with water.
GordyR said:Looks mostly fine to me mate. My only concern would be the amount of sets you are doing for your shoulders. 17 Sets is a lot for a large muscle group let alone a small one like your shoulders. Granted not all the exercises directly isolate the shoulders but still...
Do your shoulders respond well to high volume? If so then stick with it mate. If not then consider dropping a few sets. Maybe concern yourself more with the side delt rather than the front delt which gets hit pretty hard on Chest day also.
One more thing, when you say Biceps #1, #2 and Triceps #1, #2, what exercises do you do there?
Balddog said:Shoulders is my favourite day I even threw in 3 sets of shoulder press at the end...
This morning my shoulders are dead...My shoulders are good with volume..but even so, maybe ill drop the front raises like you suggest...
Biceps and triceps...I didnt list what id do because i dunno..ive never noticed much of a diff between any kind of curling and/or tricep exercises so ill just do whatever comes to mind at the time...Yesterday I did dips and overhead rope pulls.
GordyR said:Mate, If high volume for shoulders works for you then stick with it! We are all different. I need to really blast my triceps to induce hypertrophy which is extremely unusual considering they get hit with just about every pushing exercise there is. You would probably think I am crazy if I posted my tricep workout. But it works for me
