- 19 May 2018
Hi
Firstly I'm not sure if this should've been in graphics card or home cinema, please move if necessary.
I have purchased the 55" LG OLED television. I have a number of UHD movies on my hard drive. My graphics card is old (radeon HD6900) and maximum output is HD resolution. There is no way I've found to force the higher 4k resolution.
So if I want to watch 4k from pc, I conclude I need a new GPU. Am I wrong?
However, if I were to put the films on an external hard drive, connect to TV and play from the TV, then I would get UHD resolution. Again is this conclusion correct?
If both conclusions correct, my dilemma would be deciding if investing in external hard drive that I can connect to television or upgrading GPU is the better option.
My gaming days are all but over, so I really just need my GPU to handle the UHD resolution for movie watching now. I suppose if any new GPU was benchmarked against my current HD6900, then just to be better than that would be suffice.
Is this possible on a budget???
Ive seen some Radeon cards at £59 that say will play 4k, but unsure if the other specs are better than my hd6900, but it has been discontinued and regarded as legacy for a year or two now.
Any and all advice welcome. Thanks.
