Can you try it in another PC ? Can you try PC with another monitor or a TV ?So you're suggesting to send it back as it's broken?
Sounds faulty to me.
So the 24 pin is plugged in to the right slot, the 8 pin is plugged into the top left corner which is powering the CPU. (took the GPU out so it's not plugged in or powered) the power isn't turning on, so i unplug this 8 pin powering the CPU in the top left corner and then turn PC back on and it all starts but SOON as i plug this 8 pin back in the whole thing trips out.
The 8 pin power connector that plugs into the motherboard is different from the one that plugs into the GPU. If your PSU is modular, make sure you have both cables correct at both ends.
I got another single black and yellow cable but just 4 pin no adapter on which i wasn't using - guessing i need to buy an 4 pin to 8 pin adapter to use for my GPU?
I plugged the other 4 pin power connector I wasnt using into this and seems to be fine now. However still displaying no signal on both monitors and it keeps cutting out then rebooting so I reckon the CPU is getting too hot as the heatsink I got is too small.
So there's a 6 pin which has an adapter which makes it an 8 pin plugged into the GPU
4 pin which i plugged into the CPU slot in top left
24 pin plugged into the motherboard
* View the photo's and PSU here - https://imgur.com/a/5NlXtEc
PSU - POWWA Switching Power ATX-S600 PSU
