Digital Foundry: Can you go into depth on the wins asynchronous compute gave you on the consoles and any differential there between PS4 and Xbox One?
Jean Geffroy: When looking at GPU performance, something that becomes quite obvious right away is that some rendering passes barely use compute units. Shadow map rendering, as an example, is typically bottlenecked by fixed pipeline processing (eg rasterization) and memory bandwidth rather than raw compute performance. This means that when rendering your shadow maps, if nothing is running in parallel, you're effectively wasting a lot of GPU processing power.
Even geometry passes with more intensive shading computations will potentially not be able to consistently max out the compute units for numerous reasons related to the internal graphics pipeline. Whenever this occurs, async compute shaders can leverage those unused compute units for other tasks. This is the approach we took with Doom. Our post-processing and tone-mapping for instance run in parallel with a significant part of the graphics work. This is a good example of a situation where just scheduling your work differently across the graphics and compute queues can result in multi-ms gains.
This is just one example, but generally speaking, async compute is a great tool to get the most out of the GPU. Whenever it is possible to overlap some memory-intensive work with some compute-intensive tasks, there's opportunity for performance gains. We use async compute just the same way on both consoles. There are some hardware differences when it comes to the number of available queues, but with the way we're scheduling our compute tasks, this actually wasn't all that important.
Digital Foundry: Will we see async compute in the PC version via Vulkan?
Billy Khan: Yes, async compute will be extensively used on the PC Vulkan version running on AMD hardware. Vulkan allows us to finally code much more to the ;metal'. The thick driver layer is eliminated with Vulkan, which will give significant performance improvements that were not achievable on OpenGL or DX.
Digital Foundry
o you foresee a time where async compute will be a major factor in all engines across formats?
Billy Khan: The time is now, really. Doom is already a clear example where async compute, when used properly, can make drastic enhancements to the performance and look of a game. Going forward, compute and async compute will be even more extensively used for idTech6. It is almost certain that more developers will take advantage of compute and async compute as they discover how to effectively use it in their games.
