Guide for HTPC
Ok thanks oxy
I have one more stupid question ;)
Noticed that monochrome is designed for 1366x768 resolution but my TV will be 1024x768, will I be stuck with the default crappy skin ? :p
Yeh but not installed, still configuring Moving pictures. Just finished all the art work. I like the film strip view. but I don't get the synopsis with it, like the other views. is there a way to enable it?
I dont think you do get it untill you click the film. I can't check as I formatted my pc this week and aint re-installed MP yet.
I'll stick to list view then.
Can't get tv series working.
I'm using vob/ifo files so straight dvd copy. I have to manually assign them. But then it doesn't show up in media portal.
Does it not work with vob files?
I read on a website the following
CoreAVC does not support hardware acceleration (purely a software decoder, good for less powerful CPUs and those with no GPU hardware acceleration capabilities).
is that true? So in my case, I have a 8800GT, I'd better use another codec?
yep
acidhell - check the tv plugin guide, Im not sure if it does, all mine are avi. It is also really fuuny aboiut how u name your files.
I name all mine TITLEs01e01.avi it picks everything up that way
the latest CoreAVC codec supports NV acceleration, whether or not your card is included i've no idea but being a 8800GT i'd assume you're good to go.
It'll work, but I find performance is crap.
If you have any problems CoreAVC is definitely the way to go.
ffdshow works fine for h264 material, just as good as Core tbh.
Hardware acceleration is only really beneficial when you have a weak CPU which cant handle the processing itself. With HA the GPU takes care of things taking the stress off the CPU.
Any descent Core2Duo will happily run 1080p material fine - even if it is working 70-90%.
As an example:
My E2140 @ 2.6Ghz with my onboard X1200 graphics with CoreAVC plays 1080p @24Hz material fine. I get no stuttering or dodgy artifacts. I have AC3filter sending the audio to my AV amp via HDMI aswell. I've never had any problems. It plays all media files brilliantly/flawlessly!
I should however point out that during 1080p HD playback, my CPU is stressed to around 80% load and temps are around 55*C. This is with a Scythe Mini Ninja running at the lowest setting (800rpm) and 1 case fan running at 800rpm also.
For those of you who can enable HA then that's good but for those who cant dont worry as its not the end of the world. The end result is the same. Just means that those with HTPC's without HA are working a little harder :)
yep found it thank you :)
I managed to set up most of the stuff, just needs a few adjustements.
We could watch a BSG episode hehe ! Gotta say that stuff is awesome, on my crappy TV, can't wait to get the 42PX80.
I just have a question, first I downloaded the monochrome skin 2.5 which is on the website but then when I launch mediaportal I get an error saying that the skin is not working for this version of mediaportal 1.0 ??
Secondly, I did not figure how to launch directly the my tv series plugin and movie from the home screen? I get the option to watch videos but this is for the basic thing provided which I do not use, I'd like to directly launch my plugin how can I do this?
ok erm point 1) the not 1.0.0 "error" you need to edit your reference.xml (think it was called that" with notepad. Near the top it will say 9.4.0 or summit change it to 1.0.0 - error goes away then.
Second point, configuration > plugins > click launch in home for movies and TV.
PS: im going from memory, u may have to look but its defo in the plugin section.
