- 16 Nov 2003
- On the pale blue dot
i would advice everyone not to use the internal player in MediaPortal. It is rubbish!
Hi photoshop, can you expand on that and also what do you use instead?
thank you mate will check that out this evening, when the new telly ARRIVES
One more thing tho, most of the stuf works fine but I have one more issue I'd like to fix with your help.
Is it possible to display on screen information with KMPlayer? Like when I pause, fast forward, change volume etc..? Would come handy because at the moment nothing is displayed.
Shall I use the SVN version of media portal or the 1.0.0.0 is fine?
I have some issues with media portal and codecs
First, geez the 42PX80 is a BEAST, huge TVbut very nice also!
Ok here are my present issues, that I hope you can help with guys, don't let a wee newb alone in his misery!
Some really bizarre thing happening is while using the monochrome skin, I can't get moving picture to work at all, all I get is that screen with all the fields replaced by the string refereing to the plugin, ie movingpicture.title etc.. but when I'm using blue3 skin, it works perfectly and I get everything to work correctly.
TV Series works nicely but when I finish watching a movie, it launches a second time, apprently using the internal media player. This is rather odd because I specified in the options that I wanted to use KMPlayer exclusively.
Also photoshop, you are not using the latest version of the monochrome skin are you? Because my TV Serie view does not look like yours at all.
What do you do with shows that are not present on thetvdb and therefore that you can't add to the database? For example I have some NHL matches I'd like to add to it but I can't get do it because of course it is not a real serie per se.
I've got that exact keyboard and there is one glaring flaw with it that I've come across - when you're using it on an otherwise idle PC there are no problems at all, but if you start downloading using wireless as well then there is serious lag that gets worse the faster you're downloading.
When playing mp3's back through my Onkyo will the audio be ok if connected to the amp via HDMI?
HDMI Will be fine for all audio/video needs. Its just a means of bridging a connection from HTPC to Amp.
I will lose all the processing of the XFI though?
Why will you need it if the amp will be doing the processing....?
