Caporegime
Find the nearest female and squat her..
Errr... sort of.
Feet just outside of shoulder width, core braced, shoulders back and dumbell up just under your chin.
Push your knees out WIDE as you sit down between your ankles. Keep your shoulders back and core tight as you do this; this should keep your torso almost vertical (or pretty close).
See how far you can go down (knees out WIDE!!! and shoulders BACK!!!). IF you can get to parallel, then great. If you can't, don't force it, and carry on with your mobility.![]()
Just get a quick vid at home and squat with your arms out or on your chest or something.
That last rep on the first vid is exactly what you don't want to be doing I would have thought, you kind of snap your butt back, look up and do something with your spineWith load, that's going to hurt presumably.
Yours, with bluntness and love,
icecold
xxx
[/SIZE][/SIZE][/SIZE][/SIZE]
What I have done is widen my stance and tried to overly slow the movement in the first portion of the video. What you can see is this makes it a lot harder to keep balance, I cannot load my legs correctly as they are already bracing inefficiently and I can't bring them past vertical, and it makes back control a lot harder.
In the latter portion of the clip I widen my stance, screw in to the floor through my heels, make sure I have a neutral spine, and brace my core.
By doing all of the above it allows room for my knees to be pushed out, it improves stability from the beginning of the movement, I can retain full control and balance rather then having to fight for balance.
Hopefully you can see the difference in doing these things. Hopefully the vid is helpful/useful in even the smallest way![]()
The movement shouldn't feel forced. I wouldn't suggest that you need to move fast, but your taking along time on each rep. I felt when mimicking your movement pattern it felt forced and uncomfortable and I don't know if I would have been able to do it much faster anyway.
Take notes with you next session and find a natural movement, if it looks forced and disjointed then your doing it wrong.
Where are you based, is there not a gym rat near you at all?
Ice, I tried that squat to stand with reach that you linked to, and I can't do it![]()
Which bit can't you do?
How can my body be so frail and such a pussy? How can I be so inflexible at 18?![]()
Okay at the moment I am trying to do this, but as soon as I put my leg against the wall, when I try to bring my other leg forward it feels like my quad is about to snap so I can't actually do it. Does this mean that my quads are super tight as well?
Wow, am I too inflexible to do mobility work?![]()
Because you've never tried doing this before?
Nope. You're just inflexible.![]()
Your over thinking it, I think your trying to do far to much mobility, and unless you spend 23 hours a day cramped in a box, literally, then you shouldn't be so tight that you are not able to squat. I have a feeling it's just a case of you not getting the movement, and over thinking it.
