***Gym Exercise Guide, and Form Discussion/Feedback***
Set a pb with the squat. 35 kg. Woo! Though form wasn't perfect. Not sure how far from perfect it was though.
Also did some presses. Are these looking okay?
Didn't do deadlifts like the stronglifts program suggests. Did 3 sets of chins to failure instead.
Squats: still improving. Your back is better, but still moving too much. Abs on knees out more.
OHP: Don't nod your head under the bar, move your shoulders through slightly. Also, keep your abs on and ribcage down.
Your next piece of the puzzle to work on: thoracic extension. Get some.
Gave high bar a whirl tonight. They felt good, but noticed my hips rotating at the bottom. I'd appreciate some feedback. If they aren't too snapped up I may do them on my leg day after low bar. My hamstrings/glutes certainly need some more loving which will probably go a long way to help that bottom position.
look at dem knees! look at them! :p
p.s. wife was along hence the music
p.p.s my traps aren't happy with me now
By lifting my heels off the floor a bit I can get into a better position so it's definitely a case of ankles limited forward knee travel.
Oh I don't disagree, freeing up your ankles will bring extra forward range which is no bad thing. You do want to be able to get your knees out more as well though, and that also starts at the ankles :)
More ankle range
More knees out
More upright torso
Break more deliberately at the knee and stay as upright as possible. For these light sets, sit at the bottom and accentuate a good position.
Cheers. After watching a few videos I can see I'm a little way off the proper high bar bottom position. I'll smash them ankles up over the next few weeks and report back.
I think if my knees can go forward some more then I can stay more upright.
Exactly right.
IMO if you want to do something to help improve your mobility and can only make room for one then front squats > high bar. If your just looking for something a little different then high bar will get you moving through a greater rom then low bar, and will hit things differently. I have really started to enjoy fronties especially once getting the grip right.
Any feedback on my BOR's from the previous page anyone?
