- 5 Aug 2006
- Derbyshire
hi, my pc froze and I restarted it to get SMART (on my dfi nf4) reporting my hard drive had failed, or is about to. I reset it again and it was correct, no windows post, and upon another reset it came up with the menu about windows in safe mode etc etc, and whatever option I chose stil no boot into XP. I tried the hard drive in my external caddy on my laptop aswel but the hard drive is dead, even though it makes the beep-beep XP noise happen (you know the one where you add a plug and play device like a usb stick). i dropped the hard drive from a hight of 30cm to see if the arm was stuck, then put the hard drive in my home freezer to contract all the bits of metal to see if that helped but it stil won't work. Oh well was only a 40gig WD IDE, but a hard drive shoudl fail after 3/4 years, and this drive had my windows set up with my 50hour oblivion save on
just wondering what every1s thoughs are on this
