help choosing rad
2 Aug 2006
Liverpool
hi, I'm purchasing a watercooled pc from OCUK and have settled on the following
intel I7 8700K 5.0GHZ Ultra Edition
1080ti Watercooled
Asus Maximus Hero X with monoblock
2x rads 1 360 1 420 (if it will fit)
Thermaltake View 71
Corsair ML120/140 Pro RGB
Team Group Night Hawk RGB 16GB 3000MHz
I need help picking the rads, the case can change if needed, I want a very cool system but also quiet, I was thinking the Following for the rads
360 - EK 360PE
420 - XSPC AX420
any others I should consider
I thought you were considering a 4-fan or a 3-fan rad for a moment there :p
Consider going with 140mm fan ones over 120mm fan ones if your case has brackets - you can spin the fans a little slower to reduce noise.
(you get more radiator with a 360mm vs a 280mm radiator though - more cooling)
does anyone know what thickness the TT VIEW 71 can accomadate if using 1x 360 up top and 1x 420 in front, I was thinking EK COOLSTREAM 360 PE uptop but not sure what 420 to get
ok I think I'm just going to go with 2x360x64 rads, I can go 420x55 top and 360x64 front but I don't want the exhaust to be bigger than the intake, Here is the manual with thickness but I don't if I can do it the other way
