- 2 Aug 2006
- Liverpool
I don't know, the motherboard and gpu will be watercooled, do you think I do
I couldn't say to be honest, I've always kept a little air flow in the case just to be sensible. I'm quite new to water cooling but it seems risky to only cool the... Water cooled bits. Maybe I'm paranoid.I don't know, the motherboard and gpu will be watercooled, do you think I do
I've always found thicker rads perform better, so that's what I always buy for my PC buildswhats more important smaller thicker rad or larger slimmer rad, do OCUK sell HWL
Not a lot in it, but personally I'd go for the 2 x 360/60 setupI'm thinking 2x 360x60 would be better than 1x 420x45 and 1x 360x60
It's not just CFM you need to check, especially with rads, you need to check the 'Static Pressure' rating, the higher the better, but also check the noise levels are acceptable to you as wellwould the fans be strong enough cfm wise
Ah right, your OP states you're getting the Corsair ML120's?there EK 120ER RGB, I don't know
Which speed are you getting? The 1150rpm models have poor SP, but the full fat 2200rpm models have excellent SP but at the cost of being very noisy at full speed.there EK 120ER RGB, I don't know
