help choosing rad
I have 2 x 360mmx60mm rads one is an EK XE360 and the other is an Alphacool UT60.
I use 3x Ek Varder 120ER's on the Alphacool and 3x Noctua 120 slim lines on the Ek, temps are pretty good at about 2.6 degrees delta on idle at around 600rpm so also pretty quiet and to be honest I don't have to run them over 800rpm at any point.
Larger is defiantly better but their is also the law of diminishing returns. To be honest any 360x60mm rad will
suffice just go with whatever suits your budget.
so whats better
2x 360x60
1x 360x60 1x 420x45
2x 360x30 with push/pull
You won't notice much difference between 2x 360x60mm and 1x 360 420x45 imo so just go with whatever is cheapest or looks/fits better.
I'd avoid slimmer with push/pull to be honest as slimmer rads respond less to push pull than thicker and it'll be more expensive with more parts to go wrong.
what software are you using
I normally just use the mb software
It takes a little while to setup but once you've set it up how you like it you never have to touch it.
Is it worth it? That's up to the individual but you can do way more with it than any motherboard or software like speed fan, you can literally adjust almost anything.
I brought the Aquaero 5LT as it was only about £50 but if I was to do it again I'd buy the 6LT as it has more pwm fan connections that supply more power.
I wouldn't be put off with the setup as there are many on here that would be able to help you.
