help choosing rad
Go with 140's if you can fit them - they can run slower than 120's moving the same amount of air.
You might be able to fit more 120's in though - and the radiators are more common.
I don't have the case or ram, Thermaltake say it supports 360x64 at front and top or 420x55 top 360x64 front
That suggests your going to be tight for space up top remember that a fan adds 25mm on top of the thickness of the rad.
I have these fans up top and even though I am not limited for space, as I have a Themaltake X71 which has plenty of room in behind, I didn't want too much hanging down for aesthetics.
My basket at Overclockers UK:
Total: £20.47 (includes shipping: £3.48)
ok I think I'm just going to go with 2x360x64 rads, I can go 420x55 top and 360x64 front but I don't want the exhaust to be bigger than the intake, Here is the manual with thickness but I don't if I can do it the other way
thats the page
