Help Decode This Padlock!
6 Jun 2013
So I've ordered a package and the delivery driver has left it in a locked cupboard containing some water meters etc. in my block of flats. Luckily, he left a picture of the padlock with the code to unlock it:
Oh.
Can anyone please help me decode this image? I think the 3rd digit is a 2, but can't tell for sure and the others are useless to me. Perhaps someone can edit this enough to get some idea of the code
How did the delivery driver know the code? Is it written on a noticeboard somewhere?
You should also know the code if you live in the block of flats. Ask the factor, they'll probably be able to tell you.
I see the 3rd digit as 5 and 4th as 3 (or 8) if I was correct there's only 200 combinations to try given 0 to 9 is 10 digits
the top numbers look like 5239, so the code should be 6340 assuming it has 3 numbers in view and the middle row is the code
If it's wrong then you've only got another 9,999 codes to try :D
