- 25 Nov 2011
- The KOP
(Solved) Asrock Z68 Extreme4 Gen3 No display/no post
just put together new build motherboard is asrock z68 extreme4 gen3 I get no display with gpu installed? but if I remove it It post and i can get into the bios.
My gpu is a xfx hd 7950 all power is connected and on board de-bug led they is nothing lit up at all.
It starts with its post lit up but then switches off?
