- 28 Dec 2017
- Beds
Hah fair. I wouldn't make the fan a p1 issue tho, just get the holes for your cable done and do the fan hole properly. Leave the door open temporarily
Presumably you'll need intake and exhaust?
Don't underestimate how warm sealed spaces can get even with a small heat source. You'll need fresh air in and warm air out, imagine the cupboard as a big PC case. I'd drill minimal holes for now - the oOo idea might not be useful if it means air is sucked in the small holes and out the big ones.I would like to upgrade it at some point though
You can always start minimal, see how the PC copes, adapt from there. Heat and air flow air worth trying, tweaking and adjusting IMO.
