Thanks for your replies.
My list of components now are:
CPU = Intel Core i5-9600K
Mobo = Asus ROG Strix Z390-F
NVMe = Sabrent Rocket 1TB PCIe 4.0
GPU = Asus ROG Strix RX 570 4GB OC
RAM = Corsair Vengeance LPX 3000 MHz CL 15 (Low profile)
Cooler = Corsair H100i PRO RGB
PSU = Corsair RMx 850W (80 Gold)
Case = Cooler Master MasterBox MB511 (Love this one, it is the best ventilated with 3 stock fans and 1 at the rear, compliments go to Tech Deals for his recommendation)
I am very happy with the above list though the total cost is rather expensive, yet still within my budget.
Only a bit fed up with Corsair forum as I have raised a question asking about their latest Carbide 275R Airflow case, I was nearly convinced that I should gofor that one , but nobody replied me.
MB511 has several advantages: the $75 case comes with 3 stock fans at the front, and 1 at the rear however they are not PWM fans. It is very spacious inside and provides option for installation of 240mm AIO at the roof, both Silverstone RL06 and Corsair Carbide SPEC-06 as well as Carbide 275R provides no such option (pity).
I have built the rig yet, I need to figure out if I need a Flash USB Drive setup for Windows 10 installation after I have put all the hardware together. Can anyone supply me with the information, currently I only have a DVD for installation of Windows 10.
After the system is setup, I may need to setup a LCS for the RX 570, it runs far too hot.
. Choose an 8gb GPU while you're at it. A 4gb GPU is just going to annoy you.
