Help Picking Fans / Paste
I think 81-82 under stress testing is fine. If your house is anything like mine then it's at least 5 degrees higher than normal anyway!
Bit late, but this.
It's hot weather- if you're hitting low-80s while thrashing your chip with benching, then I would not be worried about it. That's as bad as it'll get. Back to normal when the ambient temp drops a bit!
